Sync issues after trial expires and purchase plan
So my trial has expired and I purchased the plan, following that sync no longer works between my android phone and mac client.
When I select the sync tab on the mac client it gave an error along the lines of ā€˜could not find function getSync() on remote’, I can’t reproduce/recall the exact error message.
After logging out and logging back in for both android and mac clients syncing works as per normal. You might want to look into this issue to ensure a smooth transition for paying users.
  • Platform: (macOS/Windows/Ubuntu/iOS/Android)
  • Platform version: (Mojave/10/16.04)
  • App Version: (4.3.0)
Hi Abdul,
Thank you for the report and buying Inkdrop.
That’s weird, I’ll look into it and fix it if I could reproduce it.
Maybe that’d be solved simply by relaunching the app.
