Thanks @craftzdog for your quick transport
Error: Request failed with status code 500
at createError (C:\ieu\ink\node_modules\axios\lib\core\createError.js:16:15)
at settle (C:\ieu\ink\node_modules\axios\lib\core\settle.js:17:12)
at IncomingMessage.handleStreamEnd (C:\ieu\ink\node_modules\axios\lib\adapters\http.js:237:11)
at IncomingMessage.emit (events.js:203:15)
at endReadableNT (_stream_readable.js:1145:12)
at process._tickCallback (internal/process/next_tick.js:63:19)
config:
{ url: 'https://api.inkdrop.app/',
method: 'get',
headers:
{ Accept: 'application/json, text/plain, */*',
'User-Agent': 'axios/0.19.0',
host: 'api.inkdrop.app' },
transformRequest: [ [Function: transformRequest] ],
transformResponse: [ [Function: transformResponse] ],
timeout: 0,
adapter: [Function: httpAdapter],
xsrfCookieName: 'XSRF-TOKEN',
xsrfHeaderName: 'X-XSRF-TOKEN',
maxContentLength: -1,
validateStatus: [Function: validateStatus],
data: undefined },
request:
ClientRequest {
_events:
[Object: null prototype] {
socket: [Function],
abort: [Function],
aborted: [Function],
error: [Function],
timeout: [Function],
prefinish: [Function: requestOnPrefinish] },
_eventsCount: 6,
_maxListeners: undefined,
output: [],
outputEncodings: [],
outputCallbacks: [],
outputSize: 0,
writable: true,
_last: true,
chunkedEncoding: false,
shouldKeepAlive: false,
useChunkedEncodingByDefault: false,
sendDate: false,
_removedConnection: false,
_removedContLen: false,
_removedTE: false,
_contentLength: 0,
_hasBody: true,
_trailer: '',
finished: true,
_headerSent: true,
socket:
Socket {
connecting: false,
_hadError: false,
_handle: [TCP],
_parent: null,
_host: '#PROXY#.#COMPANY#.ch',
_readableState: [ReadableState],
readable: true,
_events: [Object],
_eventsCount: 7,
_writableState: [WritableState],
writable: false,
allowHalfOpen: false,
_sockname: null,
_pendingData: null,
_pendingEncoding: '',
server: null,
_server: null,
parser: null,
_httpMessage: [Circular],
[Symbol(asyncId)]: 5,
[Symbol(lastWriteQueueSize)]: 0,
[Symbol(timeout)]: null,
[Symbol(kBytesRead)]: 0,
[Symbol(kBytesWritten)]: 0 },
connection:
Socket {
connecting: false,
_hadError: false,
_handle: [TCP],
_parent: null,
readable: true,
_events: [Object],
_eventsCount: 7,
writable: false,
_sockname: null,
_pendingData: null,
server: null,
_server: null,
parser: null,
_header:
'GET https://api.inkdrop.app/ HTTP/1.1\r\nAccept: application/json, text/plain, */*\r\nUser-Agent: axios/0.19.0\r\nhost: api.inkdrop.app\r\nConnection: close\r\n\r\n',
_onPendingData: [Function: noopPendingOutput],
agent:
Agent {
_events: [Object],
_eventsCount: 1,
defaultPort: 80,
protocol: 'http:',
options: [Object],
requests: {},
sockets: [Object],
freeSockets: {},
keepAliveMsecs: 1000,
keepAlive: false,
maxSockets: Infinity,
maxFreeSockets: 256 },
socketPath: undefined,
timeout: undefined,
method: 'GET',
path: 'https://api.inkdrop.app/',
_ended: true,
res:
IncomingMessage {
readable: false,
_events: [Object],
_eventsCount: 3,
socket: [Socket],
connection: [Socket],
httpVersionMajor: 1,
httpVersionMinor: 1,
httpVersion: '1.1',
complete: true,
headers: [Object],
rawHeaders: [Array],
trailers: {},
rawTrailers: [],
aborted: false,
upgrade: false,
url: '',
method: null,
statusCode: 500,
statusMessage: 'handshakefailed',
client: [Socket],
_consuming: true,
_dumped: false,
req: [Circular],
responseUrl: 'http://#PROXY#.#COMPANY#.ch:80/https://api.inkdrop.app/',
redirects: [] },
aborted: undefined,
timeoutCb: null,
upgradeOrConnect: false,
parser: null,
maxHeadersCount: null,
_redirectable:
Writable {
writable: true,
_events: [Object],
_eventsCount: 2,
_options: [Object],
_redirectCount: 0,
_redirects: [],
_requestBodyLength: 0,
_requestBodyBuffers: [],
_onNativeResponse: [Function],
_currentRequest: [Circular],
_currentUrl: 'http://#PROXY#.#COMPANY#.ch:80/https://api.inkdrop.app/' },
[Symbol(isCorked)]: false,
[Symbol(outHeadersKey)]:
[Object: null prototype] { accept: [Array], 'user-agent': [Array], host: [Array] } },
response:
{ status: 500,
statusText: 'handshakefailed',
headers:
{ 'content-type': 'text/html',
'cache-control': 'no-cache',
'content-length': '2956',
'proxy-connection': 'Close' },
config:
method: 'get',
headers: [Object],
transformRequest: [Array],
transformResponse: [Array],
timeout: 0,
data: undefined },
request:
ClientRequest {
_events: [Object],
_eventsCount: 6,
output: [],
outputSize: 0,
writable: true,
_last: true,
sendDate: false,
_removedTE: false,
_contentLength: 0,
_hasBody: true,
_trailer: '',
finished: true,
_headerSent: true,
socket: [Socket],
_header:
agent: [Agent],
timeout: undefined,
method: 'GET',
_ended: true,
res: [IncomingMessage],
aborted: undefined,
timeoutCb: null,
parser: null,
_redirectable: [Writable],
[Symbol(outHeadersKey)]: [Object] },
data:
'#REMOVED#'
isAxiosError: true,
toJSON: [Function]
I voluntary removed some company’s informations (precise proxy URL and ‘data’ field which only contained our internal generated HTML error page (Handshake failed bla bla…)).
It looks like Axios doesn’t care about the strict_ssl: 0 config…
