Hi all. Can you tell me how to make spoilers?
Does this require a plugin or is there markdown code? Unfortunately I couldn’t find it in the faq.
currently you will need to use a plugin called Admonition to use spoiler. The syntax is something like this:
[[spoiler | Title]]
| content to be spoiler here. **markdown** is supported.
more info is in the github readme here: libeanim/inkdrop-admonition: An Inkdrop plugin that allows to add block-styled side content to your notes.
Hi @Artem_Palukin
For a basic spoiler you can also use the HTML standard. There is no need for a plugin for this. These also work in the mobile version. (Android)
<details>
<summary><b>Spoiler</b></summary>
Content
</details>
I totally forgot that you can also use html for that.
