Sort order affects visibility of notes
Sort order affects visibility of listed notes.
I have a notebook which have 35 note with none, completed and dropped state.
When I select this notebook, it shows only note with none state. This is correct.
After I changed sort order from Descending to Ascending, all notes in list become invisible and ā€˜No Notes’ is displayed.
  • This is reproduced on another Mac with same account.
  • This is occurred on only one notebook. Other notebook don’t have problem.
  • Platforms: Mac
  • Platform version: Mojave
  • App Version: 4.1.0
I don’t know how to reproduce it on other environment.
Hi Keiji,
Thank you for reporting it.
I reproduced the issue that notes are not displayed as expected when changed the order while viewing notes with ā€˜Completed’ / ā€˜Dropped’ status. It just disappears.
It’s a bug and will be fixed! Thanks again.
Hi, Takuya.
Thank you for your quick response and investigation.
I am waiting for fixing this issue.
Hi Keiji,
Can you please try this patch to check if your issue got resolved?
https://inkdrop-dist.s3-ap-northeast-1.amazonaws.com/tmp/Inkdrop-4.1.0-Mac-patch-1.zip
Hi Takuya
This problem was not fixed with patched app.
I tried to logout and login again. But it was same.
This notebook have 2 active, 39 completed and 4 dropped notes.
2 notes should be listed.
But follow numbers notes are listed by sort subject and order.
Title Date created Date updated
Ascending 1 0 0
Descending 0 2 2
That’s weird.
Can you please try rebuilding the FTS index?
You can trigger it from the application menu: Developer -> Rebuild FTS Index
I tried to rebuild FTS index. But this problem was not fixed.
Ah okay, reproduced!
It should fix the issue. Can you please try it again with this patch?
https://inkdrop-dist.s3-ap-northeast-1.amazonaws.com/tmp/Inkdrop-4.1.0-Mac-patch-2.zip
Fixed!! Thank you!
Great!
