Thank you for the question.
That’s d be an advanced way to use Inkdrop.
You have to understand the APIs to hack it.
Actually you can do that by writing a custom script.
The documentations about creating a note template and about the editor would be helpful.
You can insert a text at the cursor position like so:
var cm = inkdrop.getActiveEditor().cm
cm.replaceSelection('foo')
