Self signed certificate in certificate chain when trying to login
When trying to install the software, I get the login screen. When trying to login, I see:
Sorry, unexpected error occured. Self signed certificate in certificate chain. Please check your system configuration or report the problem.
When I click for more info:
“Error message:
self signed certificate in certificate chain
Status code:”
I’m at office, and my company has a proxyserver.
  • Platform: (Windows)
  • Platform version: (10)
  • App Version: (3.22.2)
Please read this documentation:
https://doc.inkdrop.info/manual/working-behind-a-corporate-web-proxy
I was facing this error in macbook m1 even after doing all the actions as mentioned in https://doc.inkdrop.info/manual/working-behind-a-corporate-web-proxy . Looks like somehow my inkdrop folder was messed. Uninstalling inkdrop doesn’t delete this inkdrop folder. So after uninstalling I had to delete this folder manually. A fresh install after this and setting strict-ssl to false worked for me.
Sharing it here so that it could help someone.
@craftzdog I don’t face this proxy errors in other note taking apps such as remnote, obsidian, logseq, etc… Is it due to atom based architecture that you are using for this app?
@anon50734047 Do you mean other apps work well behind your proxy with a self-signed cert? If so, they don’t verify SSL certificates, which is insecure.
strict-ssl=false must be required for self-signed certs.
Okay. I assume the other apps don’t enforce this. Thanks!
