Hi!
Do you plan to add search feature in a note on mobile application (v2)?
Thanks,
Hi benlac,
Yeah the search in note is an important feature. I’ll implement it!
It’s been supported. Thanks!
where can I find this feature? I’m not able to search within a note just search all notes.
Could you help me here @craftzdog?
Best
Hi Marco,
Oops, it’s not correct, the search-in-note feature is not supported yet.
I don’t remember why I marked it as solved
Sorry for the confusion.
It should be implemented as a basic feature.
Thanks for letting me know!
It has been supported in the mobile v5.
