Question
I’m afraid if I cannot resize an image by using HTML tag. Can you check it? Thank you.
- Platform: macOS and Windows
- Platform version: Mojave 10.14.4 and Windows10
- App Version: 4.0.0-beta.2
<img src="inkdrop://file:icKxWRfcy" width=200/>
Hi Kazutaka,
Thank you for reporting it.
Oops, that’s a bug. It does not treat width and height props in the renderer.
Will fix it soon!
Thank you for your reply.
Looking forwards to a fix. Thanks!
Kazutaka
It should work on v4.0.0-beta.3.
Thanks again for the report!
Yes working well. Thanks Takuya
Yeah, it works now! So quick! Thank you.
