I am learning a new language called rescript. But I am unable to see syntax highlight for that in editor. It would be helpful if support for rescript is added
// let a = () => {None}
I can see it is available by default from codemirror 6.
Do you think any other way to achieve it until codemirror upgrade is done?
Can you give me the link to the rescript language module for CM6?
I was wrong about code mirror. Its highlightjs I believe.
Thanks. Although it is ocaml highlighting, for now I can use it.
