I have tested inside my existing documents and the same issue happens.
Hi Guillermo,
Thanks for the report. I don’t understand what’s the issue. Can you put a screenshot?
Hi, I’m attaching the result in iOS which I would expect to see in Desktop (Windows).
Depending on which preview theme you use, it may change the text color for strong-emphasized (**) text. If you want bold text with red color, try this:
<span style="color: red; font-weight: bold; font-size: 24px;">This is an Important Message</span>
