Hi there,
first of all, thanks for that great app, really is gonna make my life easier
I’m just having trouble to get the mapping of jk to to work… I already placed all of that in my keymap.json file:
‘.CodeMirror.vim-mode.normal-mode textarea’:
‘jk’: ‘vim:reset-normal-mode’
‘.CodeMirror.vim-mode.insert-mode textarea’:
‘jk’: ‘vim:exit-insert-mode’
‘.CodeMirror.vim-mode.replace-mode textarea’:
‘.CodeMirror.vim-mode.visual-mode textarea’:
‘jk’: ‘vim:exit-visual-mode’
am I missing something?
Thanks in advance
With best regards,
Jörg
July 28, 2023, 2:26am
Hi Jorg,
Thanks for the question.
Check out this issue here:
opened 12:41PM - 07 Apr 22 UTC
closed 01:03AM - 08 Apr 22 UTC
'.CodeMirror.vim-mode.normal-mode textarea':
'jk': 'vim:reset-normal-mo… de'
'.CodeMirror.vim-mode.insert-mode textarea':
'jk': 'vim:exit-insert-mode'
'.CodeMirror.vim-mode.replace-mode textarea':
Specifically, you need a space between each key stroke as follows:
'j k': 'vim:reset-normal-mode'
'j k': 'vim:exit-insert-mode'
oh awesome – thanks so much for your reply – got it working now!
One more thing I can’t find anything about – is it easily possible to export the current note to be edited/opened up in MacVim? Also, when I use the filter with ⌘-SHIFT-F and quicksearch a note – how I jump into its main contents directly instead of the title which happens when I hit ?
July 31, 2023, 6:04am
No, opening a note in the external app is not supported
Press Cmd + Enter . The command is editor:focus.
