Thank you for reporting it.
That’s weird. Maybe the proxy setting does not work in the app.
I’ll look into it.
As I’m on vacation right now, I will work on it after Jun 19!
v4 uses PouchDB@7.
And from v7, it starts depending on node-fetch and seems like it does not refer HTTP_PROXY and HTTPS_PROXY.
A workaround would be something like:
var db = new PouchDB('url', {
fetch: function (url, opts) {
opts.agent = new HttpsProxyAgent(process.env.HTTP_PROXY);
return PouchDB.fetch(url, opts);
I tried the uploaded patch on command prompt But error occurred.
And I Logged out inkdrop. and I run patch then not error occurred.
but I logged in inkdrop and i run path then error occurred.
[bugsnag] Loaded!
2019-06-19T05:02:42.348Z app:error error during auto update: Error: Can not find Squirrel
at AutoUpdater.emitError (C:\Users\y_ono\Downloads\Inkdrop-4.1.0-Windows-patch-1\resources\electron.asar\browser\api\auto-updater\auto-updater-win.js:70:24)
at AutoUpdater.checkForUpdates (C:\Users\y_ono\Downloads\Inkdrop-4.1.0-Windows-patch-1\resources\electron.asar\browser\api\auto-updater\auto-updater-win.js:41:19)
at e (C:\Users\y_ono\Downloads\Inkdrop-4.1.0-Windows-patch-1\resources\app.asar\main.js:1:176704)
at C:\Users\y_ono\Downloads\Inkdrop-4.1.0-Windows-patch-1\resources\app.asar\main.js:1:176789
at t.default (C:\Users\y_ono\Downloads\Inkdrop-4.1.0-Windows-patch-1\resources\app.asar\main.js:1:176816)
at t.default.start (C:\Users\y_ono\Downloads\Inkdrop-4.1.0-Windows-patch-1\resources\app.asar\main.js:1:59801)
at App.i.app.requestSingleInstanceLock.i.app.on (C:\Users\y_ono\Downloads\Inkdrop-4.1.0-Windows-patch-1\resources\app.asar\main.js:1:55117)
at App.emit (events.js:187:15)
at App.EventEmitter.emit (domain.js:442:20)
at App.topLevelDomainCallback (domain.js:121:23)
2019-06-19T05:02:42.373Z app:error Failed to load local database: TypeError: Cannot set property 'fetch' of undefined
at t.default.initDataSync (C:\Users\y_ono\Downloads\Inkdrop-4.1.0-Windows-patch-1\resources\app.asar\main.js:1:107692)
at t.default.loadDatabaseAndSync (C:\Users\y_ono\Downloads\Inkdrop-4.1.0-Windows-patch-1\resources\app.asar\main.js:1:66378)
[bugsnag] Report failed to send窶ヲ
Error: connect ETIMEDOUT 35.186.205.6:443
at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1161:14)
{ Error: connect ETIMEDOUT 35.186.205.6:443
errno: 'ETIMEDOUT',
code: 'ETIMEDOUT',
syscall: 'connect',
address: 'xx.xxx.xxx.x',
port: 443 }
