I am on Windows 10 and was using the latest version 4.6.1.
I thought I would try out the beta version. I went to preferences and checked the beta option. Nothing happened. I assumed I needed to restart the application. I did so, and could see on my network monitor that something was being downloaded. After the download finished, nothing happened. Ok, again I assumed the program needed to be restarted. So I restarted the application. The hourglass icon showed for a second and then nothing happens.
Now if I click on the inkdrop icon that is all that will happen. Hourglass for a second, and nothing happens. i.e. inkdrop does not start. If I look in the Task Manager running applications I donāt see anything with inkdrop.
Good to hear that it worked.
Sounds weird, I will keep this topic open so that other people can report the same issue.
Please let me know if you found how to reproduce it.
Kind of annoying that the automatic updates donāt work for me. The app downloads the update, but then the next time I try to launch the app, nothing happens (this was for the v5 update). If I install from the setup package then it works ok. Iām on Windows 10 x64. I wonder how many of your users use Windows 10, and if any of them experience the same issue. As mentioned above, Iāve experienced the same issue with another electron based app, so it seems related to the electron update mechanism.
Looks like the issue depends on your environment.
If the auto update doesnāt work for many users, I should have got the same report from others but only you at the moment.
Can you find any related issue on their repository here?
