FYI, another option would be to subscribe onNoteChange
Just a little update, this plugin is now at version 0.4.0.
- Presentation is updated when you are saving the note (thanks to @jmerle ).
- On macOS
reveal-md
is started automatically (optionally you can still start it manually)!- Tested with Windows 10 and it did not work with automatic, so user need to use same manual process as before.
- Instructions updated.
- Improvement to regexp of speaker notes.
I have few minor changes in mind to add for release v1.0.0. When it is released I start to use semantic versioning.
Just noticed when installed to whole new computer, that newer version was released of the required reveal-md
and at least the speaker notes donβt seem to work correctly. Not sure if I can fix it as the feature comes straight from the reveal-md / reveal.js.
As a workaround, if installing to new computer. You should install reveal-md
with the latest version before v4, like:
npm install -g reveal-md@3.5.0
Iβll update this info to the README also.
