PreferencesのThemaを開くとクラッシュする
PreferencesのThemaを開こうとすると以下のエラーがでます。
ipm updateは実施しましたが変わりませんでした。
どのようにすればエラー解消されるでしょうか…
TypeError: Cannot read property 'metadata' of undefined
    at Object.getCurrentThemeName (file:///Applications/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:4:207427)
    at Object.render (file:///Applications/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:4:207204)
    at Mh (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.production.min.js:173:192)
    at Lh (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.production.min.js:172:282)
    at mj (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.production.min.js:247:361)
    at jj (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.production.min.js:216:164)
    at Z (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.production.min.js:210:471)
    at $i (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.production.min.js:206:372)
    at /Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.production.min.js:114:115
    at exports.unstable_runWithPriority (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/scheduler/cjs/scheduler.production.min.js:20:134)
    at vf (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.production.min.js:113:325)
    at yf (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.production.min.js:114:61)
    at O (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.production.min.js:113:476)
    at fj (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.production.min.js:207:442)
    at Sd (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.production.min.js:86:240)
    at HTMLDocument.__trace__ (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/@bugsnag/browser/plugin-inline-script-content/inline-script-content.js:138:30)
  • Platform: (macOS)
  • Platform version: (mojave/10.14.06)
  • App Version: (4.4.1)
Shogoさん
こんにちは。ご報告ありがとうございます。
その現象はおそらく現行のバージョンに対応していないカスタムテーマをインストールしていると思われます。
どのテーマをインストールしているでしょうか?
そのテーマをipm uninstall にてアンインストールしてみて下さい。
それでも解消しない場合は、config.cson*.core.themesの値を削除して下さい。
これでデフォルトの状態に戻せます。
連絡遅くなりすみません。
上記対応後、テーマ再設定にて治りました。
ありがとうございました!
よかったです!
