I’m sure there are a handful of users that regularly use(d) VS Code for markdown note-taking.
The VS Code Extension Markdown All-In-One has plenty of useful shortcuts. Most of these features are on Inkdrop, but are missing a few:
CTRL + < >
after the bolding/underline/italics to move the cursor outside the delimited string.
Highlighting text and entering ` to format the string to pre-formatting.
June 6, 2019, 2:10am
Hi texposure,
Thank you for the suggestions.
texposure:
Highlighting text and entering ``` to format the string to pre-formatting.
You can map a shortcut key to core:insert-code-block
as you like.
But mapping it with ``` will cause that you can’t input inline code blocks.
Please use other keys.
See the docs for detail:
Maybe it’s equivalent to running editor:go-group-right
/ editor:go-group-left
twice?
It doesn’t quite format the text, it instead replaces the entire highlighted text with an empty code block.
The functionality is close, but it’s quite a keystroke-stretch for power users. I’ve attached an example
June 7, 2019, 2:42am
hm? The command does not replace highlighted text with an empty code block but just encloses text with ```.
In your example, you can just type Cmd-Right
to put a “.” on the end of line. So you can map ctrl->
to editor:go-line-end
