How can I make InkDrop completely portable by moving the ‘Inkdrop’ folder under ‘C:\Users\XXX\AppData\Roaming’ to the application folder?
Hi Oxe,
I’m afraid that it is not possible since it assumes that the app is always running on your personal computer.
The app stores your credentials in Credential Vault on Windows, so using it on a public/shared computer is even not recommended.
