Permisions and Durations on Shared Notes
There doesn’t seem to be a way to protect notes, which I suppose means a note is completely public or not at all. Also, it looks like I have to manually un-share a note, where it would be convenient to just set a duration.
Do these abilities exist or is there a workaround I’m not aware of?
If not then is this an explicit decision to not implement or is it simply a feature that hasn’t as yet been implemented.
Love the app by the way, these aren’t deal breakers more me, though they would be really, really helpful.
Update:
I didn’t know it was possible to get the data via the API (wow!) then I suppose it’s possible to implement this myself, but, which is cool, but uh…
Hi naftali,
Sorry for the delay and thank you for the suggestion.
Currently you have to unshare your notes manually.
The note sharing is just a supplemental feature since Inkdrop is a personal note-taking app and not for team-work.
So I’m afraid that permissions and durations on shared notes are not planned to be supported.
Yes you can make it by yourself. It requires some work though.
thanks for the reply, I was expecting that :slight_smile:
great app, I intend to purchase
thank you for your understanding :slight_smile:
