Hi, Craftzdog.
Can I see the tree of headers of the note on inkdrop?
If no, I think it’s a good feature for make it easy to reach a certain topic, although you can search certain words of phrases on the notes.
The outline feature is nice to be a plugin.
Basically I don’t write long notes that need it.
So I personally don’t need it at the moment.
But I would be happy to help you if you make a plugin for it.
Related plugins that would be helpful to look over your notes:
