Curiously, now the note is showing. Probably (this is speculation from my side) a network issue make only part of the note available, and the markdown was invalid.
Thanks for sending me the note.
I found that you put the script directly into Markdown, which could cause unexpected rendering issues.
I strongly recommend using GFM code-blocks when you write code snippets in Markdown:
