I signed up as a trial user to kick the tires. I installed Inkdrop on two MacBook Pros. The notebooks/notes are not being synched between the two devices as expected. I don’t think a reinstall should be warranted since these are fresh installs.
- Platform: macOS
- Platform version: 11.3.1 Big Sur (both device)
- App Version: 5.3.0 (both devices)
- Create a trial account
- Ensure you are using the Inkdrop sync server in your “Sync” settings
- Install Inkdrop on two MacOS devices (Big Sur)
- Create a notebook with a note on each device
Attempted Remedies (these actions don’t solve the problem)
- Forcing a sync using lower right corner drop down option “Synchronize notes”
- Logging out and back in again on both devices (using lower right corner drop down)
- Restarting the app on each device
- Through the “Developer” menu choose “Reload” on each device
