So, you basically canāt insert anything between the table of contents and the next section. This is by design.
Would you, please, consider tweaking that?
That is a CSS issue. You have to tweak stylesheets for your preference:
I canāt find the styles.less file, but even if I could, I wouldnāt know what to do with it⦠Do you consider the spacing thing to be a problem? If yes, could you consider maybe tweaking the default Less file to work properly, then?
Also, would editing these affect the mobile version? Iād like the app to be consistent across my devicesā¦
Iām afraid to say no because, as I said, it is your personal preference.
The preview theme is built based on GitHubās stylesheets, which many people are used to seeing.
You can create styles.less file in your data directory.
If you donāt understand the documentation on tweaking styles, you have to learn CSS.
Editing the file doesnāt affect the mobile version. It is basically for the desktop version and on your local environment.
