A work note grows every time a phase finishes: the plan, what was done, what was verified, the follow-ups. After a few phases, it’s hard to find the current state in it.
split-long-note is a new skill that tells your agent to split such a note into one overview note plus one note per phase or topic. It moves the detail without losing any of it.
- The overview keeps the goal, the decisions, and a checklist that links to each part
- Each part note holds its plan, what was done, and what was verified
- The overview keeps its ID, so existing links to it stay valid
- Your agent reaches for it when a note gets longer than about 300 lines, or when you ask to split one
Here is an example result. Each phase got replaced with a link:
Install or update:
npx skills@latest add inkdropapp/skills
