Need help updating plugin
Hey Takuya,
Trying to update my two plugins to support v4 but got some issues:
img-small
The change is really simple. But I got this error when I try to publish the change:
$ ipm publish patch
Preparing and tagging a new version ✓
Pushing v1.0.2 tag ✓
Publishing img-small@v1.0.2 ✗
Creating new version failed: You don't have access to that package
code-fold
This is more complicated. I made the editor.codeMirror to editor.cm change as suggested, but getting this error:
Type Error: global.inkdrop.on is not a function
Help please, thanks a lot!
Hi Samantha,
Great to know that you are trying to update your plugins!
img-small
ipm now uses credentials from Inkdrop’s keychain instead of API keys.
Did you log in to inkdrop on a computer where you run ipm?
If so, can you please tell me your platform?
code-fold
I added a section for that!
You can call it instead like so:
global.inkdrop.onEditorLoad(this.handleEditorInit.bind(this));
Cheers!
This is a bug which resides on the API server. Will fix it!
It was a wrong HTTP header issue.
Can you please try ipm of this patch?
https://inkdrop-dist.s3-ap-northeast-1.amazonaws.com/tmp/Inkdrop-4.0.1-beta.1-Mac-patch-1.zip
Thanks Takuya! The img-small plugin is published!
However, the code fold isn’t working correctly yet.
I made this commit: https://github.com/moyicat/inkdrop-code-fold/commit/6ef1b0f79234d4f880eee32308772493c1e6ed16
And looks like cm is getting the correct setting:
00%20AM
But it’s not taking effect.
Can you help check it out? Thanks!
Great! :raised_hands:
I checked code-fold out and found that it works fine.
26
Maybe you are loading the old version?
lol worse–I was testing on a note that has bullet points but not # titles :joy: problem solved and published. Thanks Takuya!
haha, you’re welcome! Congrats :tada:
