My preview pane is fixed. Does not update when I choose a new note from the left panels
If you got a problem, please check if you got any error in the console log by selecting the menu: Developer -> Toggle Developer Tools.
Developer Tools Console log:
/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:115 Open error: TypeError: Cannot read property ‘componentWillReceiveProps’ of null
at ReactCompositeComponentWrapper.updateComponent (/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/ReactCompositeComponent.js:457:15)
at ReactCompositeComponentWrapper.receiveComponent (/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/ReactCompositeComponent.js:405:10)
at Object.receiveComponent (/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/ReactReconciler.js:87:22)
at Object.updateChildren (/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/ReactChildReconciler.js:84:25)
at ReactDOMComponent._reconcilerUpdateChildren (/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/ReactMultiChild.js:220:35)
at ReactDOMComponent._updateChildren (/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/ReactMultiChild.js:351:31)
at ReactDOMComponent.updateChildren (/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/ReactMultiChild.js:326:14)
at ReactDOMComponent._updateDOMChildren (/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/ReactDOMComponent.js:871:12)
at ReactDOMComponent.updateComponent (/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/ReactDOMComponent.js:700:10)
at ReactDOMComponent.receiveComponent (/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/ReactDOMComponent.js:645:10)
at ReactCompositeComponentWrapper._updateRenderedComponent (/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/ReactCompositeComponent.js:562:23)
at ReactCompositeComponentWrapper._performComponentUpdate (/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/ReactCompositeComponent.js:544:10)
at ReactCompositeComponentWrapper.updateComponent (/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/ReactCompositeComponent.js:473:12)
at ReactCompositeComponentWrapper.performUpdateIfNecessary (/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/ReactCompositeComponent.js:421:12)
at Object.performUpdateIfNecessary (/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/ReactReconciler.js:102:22)
at runBatchedUpdates (/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/ReactUpdates.js:129:21)
at ReactReconcileTransaction.perform (/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/Transaction.js:136:20)
at ReactUpdatesFlushTransaction.perform (/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/Transaction.js:136:20)
at ReactUpdatesFlushTransaction.perform (/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/ReactUpdates.js:86:38)
at Object.flushBatchedUpdates (/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/ReactUpdates.js:147:19)
at ReactDefaultBatchingStrategyTransaction.closeAll (/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/Transaction.js:202:25)
at ReactDefaultBatchingStrategyTransaction.perform (/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/Transaction.js:149:16)
at Object.batchedUpdates (/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/ReactDefaultBatchingStrategy.js:62:19)
at Object.enqueueUpdate (/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/ReactUpdates.js:176:22)
at enqueueUpdate (/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/ReactUpdateQueue.js:24:16)
at Object.enqueueSetState (/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/ReactUpdateQueue.js:190:5)
at Constructor.ReactComponent.setState (/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/ReactComponent.js:65:16)
at Constructor.onChange (/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/node_modules/alt-utils/lib/connectToStores.js:101:14)
at /private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/node_modules/transmitter/dist/transmitter.js:34:50
at Array.forEach (native)
at Object.publish (/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/node_modules/transmitter/dist/transmitter.js:33:21)
at emitChange (file:///private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:171878)
at Object.dispatchToken.e.dispatcher.register.e [as ID_1] (file:///private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:172461)
at Dispatcher._invokeCallback (/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/node_modules/flux/lib/Dispatcher.js:198:24)
at Dispatcher.dispatch (/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/node_modules/flux/lib/Dispatcher.js:174:14)
at batchingFunction (file:///private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:165219)
at e.batchingFunction.e.batchingFunction.e [as batchingFunction] (file:///private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:164708)
at e.dispatch (file:///private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:164907)
at c (file:///private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:176251)
at Object.u [as openSuccess] (file:///private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:176384)
at file:///private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:8193
at
debug @ /private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:115
(anonymous) @ browser-main.js:1
/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:115 Assistive Error: AssistiveError: Failed to open note
at file:///private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:8455
at AssistiveError Failed to open note
/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:457 Uncaught (in promise) TypeError: Cannot read property ‘componentWillReceiveProps’ of null
at Object.u [as openFailure] (file:///private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:176384)
at file:///private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-60F3FA6432EB/d/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:8787
at
updateComponent @ /private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:457
receiveComponent @ /private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:405
receiveComponent @ /private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:87
updateChildren @ /private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:84
_reconcilerUpdateChildren @ /private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:220
_updateChildren @ /private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:351
updateChildren @ /private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:326
_updateDOMChildren @ /private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:871
updateComponent @ /private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:700
receiveComponent @ /private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:645
_updateRenderedComponent @ /private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:562
_performComponentUpdate @ /private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:544
updateComponent @ /private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:473
performUpdateIfNecessary @ /private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:421
performUpdateIfNecessary @ /private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:102
runBatchedUpdates @ /private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:129
perform @ /private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:136
perform @ /private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:86
flushBatchedUpdates @ /private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:147
closeAll @ /private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:202
perform @ /private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:149
batchedUpdates @ /private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:62
enqueueUpdate @ /private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:176
enqueueUpdate @ /private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:24
enqueueSetState @ /private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:190
ReactComponent.setState @ /private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:65
onChange @ /private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:101
(anonymous) @ /private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:34
publish @ /private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:33
emitChange @ browser-main.js:1
dispatchToken.e.dispatcher.register.e @ browser-main.js:1
_invokeCallback @ /private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:198
dispatch @ /private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:174
batchingFunction @ browser-main.js:1
batchingFunction.e.batchingFunction.e @ browser-main.js:1
dispatch @ browser-main.js:1
c @ browser-main.js:1
u @ browser-main.js:1
/private/var/folders/zb/661rt9517f5087gk85bkfvr80000gn/T/AppTranslocation/16CA6C6B-0089-47C4-B1F8-6…:117 Thu, 26 Sep 2019 00:18:52 GMT Rollbar:log Successful api response. Link: https://rollbar.com/occurrence/uuid/?uuid=7230ccf34f6647a1ae418d7671943598
- Platform: macOS
- Platform version: Mojave 10.14.4
- App Version: 3.22.4
I don’t know how to reproduce.
