Multiple identical tags
It is possible to give multiple tags that are exactly the same in a note tag. This has caused multiple identical tags to appear in the tag tree.
Because I unintentionally created multiple identical tags, the categorization of the notes was divided and I did not get the expected search results.
When I entered the condition tag:hoge in the search bar, it only returned results for a single hoge tag.
20210125_234700
20210125_235902
  • Platform: Windows
  • Platform version: 10 pro 2004 build 19041.746
  • App Version: 5.2.1
Entering tags in notes.
Continue typing the same spelling of the tag without using suggestions and enter.
Hi Avis,
Thank you for reporting it.
Ah, that seems to be a bug, where the tag input should prevent adding more than one tags with the same name.
Fixed in v5.3.0-beta.1 just now :raised_hands:
It’s now available in v5.3.0🎉 Thanks again for the report. Credited here:
