What’s New
- Paste HTML as Markdown
- Paste images from the clipboard
- Editor header bar is now visible on the preview mode
- Editor header bar has full-width on the side-by-side mode
Bug fixes
- The line height setting affects the editor header bar
- Can’t type points for the line height setting
- [Beta 5.0.0 (17)] Text shortcuts staying after removing the keyboard
- [Beta 5.0.0 (17)] Newline can be added to title - #3 by craftzdog
- Iframe disabled on Android v5 beta
Current status
- Tag settings button not working
- useSelector performance issue
- Editor blank slate
- Add note FAB
- splash screen
- Bundle webeditor into the app
- iOS
- Android
- Note list order & sort
- note tasks in list item view
- open from external app with URI
- iOS
- Android
- Invalid session state
- Remember last editing note state
- iOS
- Android
- Readonly mode for note info screen
- Some MDE toolbar buttons
- Settings for editor
- Editor font size
- Editor font family
- Line height
- Line numbers
- Line wrapping
- Preview font size
- Highlight active line
Show invisible characters - Markdown list bullet marker
- Settings
- Default notebook
- Self-hosted DB
- Background sync
- Opening links in preview
- Mermaid
- TOC
- Workspace menu
- Pinned notes config path
- Restore old Revision
- Resolve conflicts
- Inline image widgets
- Insert images
- Toolbar
- Paste from clipboard
- Drag and drop
- Select multiple notes by holding items
- Batch operations
- Crash recovery
- Themes
- Share on the web
- Long-press to sync from scratch
- Show progress of upgrading the local database
New features
- Delete empty new note when closing
- Outline
- PDF export
- Add go-back and forth buttons on the editor toolbar
- Drag-and-drop support for inserting images from other apps
- Convert HTML to Markdown when pasting text from web
- Dynamic toolbar
- Link open
How to join the beta testing
Check out the following topic (forum login required):
https://forum.inkdrop.app/t/weekly-report-inkdrop-mobile-v5-is-now-available-in-beta/3610
