On macOS, Inkdropâs window âtraffic lightâ buttons donât behave as expected:
When Inkdrop loses focus the traffic light buttons should all change colour to light grey but they donât.
Other apps that depend on the traffic light buttons donât seem to work with Inkdrop. For example, I use Moom for window management which can be invoked by hovering over the green traffic light button - nothing is invoked when attempted with Inkdrop.
Is this because youâreusing non-standard buttons of some kind? At first I thought it might be an Electron quirk but the same canât be said for Slack and Atom which I also use daily.
Yeah, it seems to be a bug.
The traffic light buttons are built with HTML in order to provide the window with no title bar.
So it may cause problems like you encountered on Moom.
Unfortunately it is by design so I canât do anything for that.
