MacOs scrollbars
I have always displayed scroll bars on MacOS and they look, aesthetically speaking, very misplaced in their white and light grey colors in the ‘Default Dark UI’.
  • Platform: (macOS)
  • Platform version: (High Sierra/10/10.13.3)
  • App Version: (3.20.1)
  • Set Show scroll bars to Always in system preferences.
  • Open inkdrop and set theme to ‘Default Dark UI’.
Hi Sceptic,
Maybe it will be resolved by dark mode introduced in macOS 10.14 Mojave?
I would not count on it. Apple does not seem to care about users with scroll bars on Always visible, or any non-default settings for that matter. It’s something requested a lot. There would already be a customization option for the current scroll bar one would think. I have not managed to spot a new style for it on any coverage of the Mojave.
It might also be a long time before I would upgrade since I am using a Hackintosh and updating can be a drag.
Might using ::-webkit-scrollbar to style it, work on MacOs?
I had a brief research on this and found another issue.
::-webkit-scrollbar works as expected but it makes scrollbars always shown regardless of macOS’s scrollbar configuration. I don’t like scrollbars always shown while macOS is configured to “Automatically based on mouse or trackpad” at “Show scroll bars” section.
To solve this problem, you have to make a tiny plugin which just adds a custom CSS for it.
For example, @Samantha_Zhang has already done a similar plugin that makes images smaller in preview:
https://app.inkdrop.info/plugins/img-small
This should be helpful.
Thanks for looking into it. I don’t actually plan on using Inkdrop on MacOS all that much. I only installed and tested it since it has become part of my default set of applications. So as of now I personally don’t have the need for such a plugin. Just thought I should report it in.
In any case it seems more logical to me to place a toggle for ‘scroll bar always on’ in the theme settings for this behavior. And make the scroll bar styling a default part of a theme. Otherwise for every theme, and installed theme plugins, a custom scroll bar plugin would have to be created and switched to when you change themes.
I don’t feel like adding more preferences only for fewer people. A lot of preference support make the app complicated. Plugins are exactly the one for this case. So I can focus on core features.
I have the same issue on macOS Monterey 12.4, M1
@anon13551506 Change the system preferences:
Wow! Thanks for the quick reply!
