The latest update is the single most unpleasant experience I have ever had.
- Platform: windows
- Platform version: 11
- App Version: latest
Just open the app.
Just open the app.
Hi Robert,
Can you please tell me the following information?
Hi
Maybe you could share the exact Windows version that you use?
For example, you can get the currently installed Windows version from winver.exe. At the top, you can see your version and build number.
And I assume that the title bar looks normal to you and is only broken in the video (I mean the blacked-out areas at the top), for example, due to your recording software?
