Hi, it’d be great if there was an option to start Inkdrop with system start-up.
Another thing I would like to see is that inkdrop remembers window size.
And lastly an option to keep Inkdrop minimized (and minimize on [close] as well)
Thanks for the suggestion.
Launching Inkdrop on startup would be nice to support. Which OS do you use? You can configure it in the system config like macOS:
Inkdrop already supports remembering the window size and position.
Launching the app with minimized would be hard to support.
Im using Windows currently, I solved it by moving Inkdrop shorcut to startup files folder in Windows.
Thanks for the fast reply.
I also noticed that it remembers windows size and position now. It just didnt the first few times I launched it.
