Hi!
Iāve just updated to 3.18 and Iām encountering the following error when trying to launch inkdrop:
inkdrop
app:error Failed to init app: Error: libgnome-keyring.so.0: cannot open shared object file: No such file or directory
at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:173:20)
at Object.Module._extensions..node (module.js:598:18)
at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:187:18)
at Module.load (module.js:488:32)
at tryModuleLoad (module.js:447:12)
at Function.Module._load (module.js:439:3)
at Module.require (module.js:498:17)
at require (internal/module.js:20:19)
at Object.<anonymous> (/usr/lib/inkdrop/resources/app.asar/node_modules/keytar/lib/keytar.js:4:12)
at Object.<anonymous> (/usr/lib/inkdrop/resources/app.asar/node_modules/keytar/lib/keytar.js:58:4)
at Object.<anonymous> (/usr/lib/inkdrop/resources/app.asar/node_modules/keytar/lib/keytar.js:60:3)
at Module._compile (module.js:571:32)
at Object.value [as .js] (/usr/lib/inkdrop/resources/app.asar/main.js:1:38089)
at Object.defineProperty.value (/usr/lib/inkdrop/resources/app.asar/main.js:1:110109)
at r (/usr/lib/inkdrop/resources/app.asar/main.js:1:285)
at Object.defineProperty.value (/usr/lib/inkdrop/resources/app.asar/main.js:1:103413)
at e.init (/usr/lib/inkdrop/resources/app.asar/main.js:1:11132)
at App.n.app.on (/usr/lib/inkdrop/resources/app.asar/main.js:1:9900)
at emitTwo (events.js:111:20)
at App.emit (events.js:194:7)
+0ms
Rollbar:error Received error: Over free plan monthly limit. Project id 57343 access token b1af6b4a263447d8963dfe2650804b29. +0ms
Iām on what you would definitely call an unsupported system (Archlinux with i3wm) but this has been working fine up until the update to 3.18. I was wondering if you had any suggestions for what I might try?
Mike
