Keybindings with numbers and the shift modifier together do not work
Currently keybindings cannot contain numbers with the shift modifier together in one keybinding (eg. ctrl-shift-2)
Therefore the default keybindings for changing the note status also dont work.
I have tried to use the character in the keybinding that appears when using shift and the number (eg. shift-1 → ! - german keyboard layout) as this is the case when using the shift modifier with an alphabetic character (eg. shift-K)
  • Platform: Windows, Ubuntu
  • Platform version: 11, 22.04
  • App Version: v5.8.0-beta.1
These are a few keybindings that i have used for some testing.
not working keybindings:
"alt-shift-2"
"ctrl-shift-2"
"shift-ctrl-2"
"ctrl-shift-!"
"shift-ctrl-!"
Hi Lukas,
I looked into the source code of the Atom’s keymap module and found that it is intended:
It converts characters to the ‘with-shift’ ones if the shift key is held down.
But I guess it could be resolved by converting characters when normalizing a keystroke here:
I’ll try it.
Can you try this patch?
Thanks, it looks like it works with the patch.
I have tried this successfully with the following keybindings:
ctrl-shift-1
ctrl-shift-3
alt-shift-1
alt-shift-3
Great! Thanks for testing.
