Hi
Regarding keybinding, in settings, there is a table list the keystroke, command, source, select but it misses, imho, the most important column, which is the keystroke description, what is that command for?
Some of the keystrokes are well-known like ctrl+c
but what ctrl-alt-K
is for, for example?
It would be great if we have a description column right after the Keystroke column.
thank you!
