This might be a stupid question, but I want to insert a template mermaid graph into my notes using a hotkey. Essentially I would like to add a keybinding which always appends specific text behind the cursor. The documentation regarding keybindings only talks about the execution of commands, but not text-insertions. Is there any way to achieve this?
The easiest way is to define a custom command in the init.js and then add a keybinding that calls this command.
eg:
init.js
inkdrop.commands.add(
document.body,
'custom:insert-some-text',
const someText = `Some text!`;
const mde = inkdrop.getActiveEditorOrThrowError()
const cm = mde.cm
const cursor = cm.getCursor()
const line = cm.getLine(cursor.line)
cm.replaceRange(someText, { line: cursor.line, ch: line.length })
".CodeMirror textarea": {
"ctrl-k ctrl-p": "custom:insert-some-text"
Worked like a charm. Thank you very much!
