Inkdrop is new for me and Iâm not sure if itâs a bug.
â.CodeMirror textareaâ:
âctrl-shift-upâ: âeditor:select-lines-upwardâ
This does not work on my Windows10 laptop.
No upward movement of a selected line. Downward neither.
ctrl-shift-up duplicates cursol.
Thank you for the report.
I would like to know what you exactly want to do.
The behavior of editor:select-lines-upward is correct. It adds a cursor upward.
Thank you for your support and, Iâm so sorry, itâs just my misunderstanding and not a bug at all.
I just wanted to move a line with cursor upward or downward by some shortcut like ctrl-shift-up. Is it possible?
Anyway, Inkdrop is a kind of what I did not know that I needed very bad. Itâs really appreciated.
