Jump to Top and Window title
Hi
I’m listing here two features
Jump to the Top button/hover button
As the document gets longer and longer, it would be great if we have a button to jump to the top of the document where the toc is there to navigate between the heading instead of keep scrolling-up or pressing page up on the keyboard.
Window title
I open documents in separate windows and as I switch between windows (Ctrl+Tab), It shows “Inkdrop (2), Inkdrop <3>”.
Instead, we can change the window title dynamically to be “Inkdrop - first heading” so it will be much easier to know what each window has.
Thank you!
Hi King,
This would be nice to have as a plugin.
You can add a button to the UI.
Window title
That makes sense. It would be good to show editing note title in the window title.
Thanks again for letting me know your thoughts!
Thank you @craftzdog for your response
I will try to follow the documentation, although I’m terrible in UI :frowning:
