Issues when pasting lists into editor
(Cristian Rios) #1
When pasting Markdown containing lists indented using tabs into the editor, the lists don’t render properly in the preview
i.e.:
this text:
- test 1
	- test 2
is initially rendered as:
  • test 1 - test 2
rather than:
  • test 1
    • test 2
This can be fixed by manually going through the lists in the editor, removing the tabs, then replacing them with spaces. The preview renders correctly after doing this.
  • Platform: Ubuntu 18.04 LTS
  • App Version: 3.20.0
See above.
(Takuya Matsuyama) #2
Hi Cristian,
Thank you for reporting it.
It seems like a bug in the markdown parser which the app uses and they are aware of it:
When it got fixed, I’ll update the library.
