What the plugin does: you can use - or + in the headers to expand/shrink the whole section.
Q: does anyone have a better name? I think not everyone will search for such plugins with toggle section as first choice/ keywords?
Hi @Div_Div ,
Thanks for creating a plugin!
There is already a plugin that has a similar concept for the editor called code-fold.
So, a matching name like “preview-fold” or “section-fold” might make it easier to discover.
It looks like you already published it on the registry:
Please note that if you rename it, the existing plugin users won’t get updates under the new name.
Hi @craftzdog ,
Got it! I will then keep the name toggle-section as it is (they are 300 downloads already
), and at the same time I will update its readme in order to allow people search by the keyword fold. I think this is the most convenient approach.
A side note is that comparing with code-fold, toggle-section serves a very similar but a bit different UX:
Editor, but no visual change in the PreviewPreview, but no visual change in the EditorThank you for the suggestion, and appreciate your hard work on such a great tool!
Cool! Thanks for contributing to the community, @Div_Div ![]()
I’ll keep it going ![]()
