I am trying to use Inkdrop from the keyboard as much as possible however I donāt seem to be able to find a keyboard command to bring the note into focus once I have selected it from the note list.
I need to bring the note into focus even though it appears in the note panel because sometimes a note can be longer then the available space in the panel and I would like to scroll through it using the arrow keys.
I am relatively new to Inkdrop so I am not sure if I am missing something. Here is my current workflow:
CTRL + SHIFT + F : to navigate to the note list
Type some text into the search field to find my note
UP/DOWN arrow keys to navigate through the note list
Then to put the note into focus one of two methods:
TAB multiple times to get to note panel so I can scroll using arrow keys
CTRL + E and then CTRL + E again (going to edit mode and then preview again brings note into focus)
I currently mostly use method (2) and sometimes (1) if I want to edit some of the note metadata. I was hoping that there might be a single keyboard shortcut to bring the currently selected note into focus. Itās not a huge issue but it would make quickly referencing notes a little bit quicker. Am I missing something or is this functionality not present?
Thanks
