I am using Windows 11 and successfully installed inkdrop, but when I launch the exe file it doesn’t open. I checked the task manager and tried launching it again, but inkdrop started but the app immediately closed.
Hi Nemui,
Thanks for the report. That’s strange.
Can you please try the “App won’t launch” section of the troubleshooting and post the app logs?
I have noticed issues with starting Inkdrop on Windows 11 as well, it happened now two times during my trial period. The last time I checked the “task manager”. There were three (3) instances of Inkdrop but none had opened a window. After forcing the task to stop the application restarted without a problem.
I am not able to reproduce the error reliably. But what I noticed is that normally Inkdrop shows four (4) processes in Windows when it is started. When I was not able to start the application three (3) processes were visible, clicking the icon in the task bar did not add a new process.
Hi @anon78489713
Thanks for the report. It would be helpful if you enabled logging. It is hard to investigate without any logs
Please check out the troubleshooting above for more details.
