Inkdrop v5.11.0 - Two-factor authentication support and big launch speed improvement
Hey Inkdroppers,
I’m happy to announce that Inkdrop v5.11.0 is officially available!
:locked_with_key: Two-factor authentication support
You can now enable a time-based one-time password (TOTP) on your account to protect against unauthorized access to your account and notes.
Check out the docs on how to enable 2FA.
Thank you so much for testing the beta version of 2FA, @Lukas and @bundit_jianpinitnan!
:dashing_away: Big launch speed improvement for Windows
It addresses the following reported issue:
This was due to Windows Defender scanning the app’s resource files on startup.
I’ve managed to bundle all the files into a single ASAR file including the native modules to reduce the scanning time.
It now starts up in ~3 seconds on my machine.
Thanks for helping me identify the cause of the issue, @Micha_Huhn, @Magnus, and @Lukas!
:woman_fairy: Reduced app size by ~120MB
There is a good side-effect of optimizing the app’s build process – the app size has been significantly reduced!
  • macOS app size:
    • v5.11.0-beta.0: 542.1MB
    • v5.11.0-beta.1: 419.9MB
:lady_beetle: Other bugfix
Thank you so much for your support :heart:
