Editor improvements
- Navigation: Restore the editor position after restarting the app
- Note link: Note link search with
[[and/notelinkmatches each keyword separately- e.g.,
foo barfinds titles containing both words like"foo" AND "bar", not only the exact phrase"foo bar"
- e.g.,
- Slash commands: Add a Table command that inserts a Markdown table
- Table toolbar: Anchor the tooltip at the cursor and hide it until positioned
- Not visible on mobile, which only uses the table cursor state
- Toolbar: Disable the slash command button instead of hiding it
Bug fixes
- iOS: Crash on older iOS versions (< 18)
- [Patched Nitro to avoid an iOS 18-only libc++ symbol]
(Core: avoid iOS 18-only libc++ symbol in Swift-visible exception helpers by craftzdog · Pull Request #1824 · margelo/nitro · GitHub) - Thanks @eflores for reporting
- Note: iOS<18 support will be dropped in the future
- iPhone Duo: Move modal navbars into the iPhone Duo status bar row
Other improvements
- Android: Enable R8 for release builds (smaller bundle and slightly faster startup)
