Inkdrop becomes unresponsive and must be force-quit. This happens intermittently and seemingly without specific cause.
Platform: macOS
Platform version: Catalina 10.15.2
App Version: 4.5.1
Intermittent; cannot reproduce reliably.
Hi there! Iāve been experiencing intermittent crashing/hanging of Inkdrop (becomes unresponsive and must be force-quit) on macOS. How can I enable logging so I can get a better idea of whatās happening? The dev console is not useful because I have to force-quit and restart so any errors are cleared.
Thank you for reporting it.
Thatās strange.
Did you find any pattern on it?
For example, it happens when you saved a note, when syncing, etc.
You can run the app from Terminal ( /Applications/Inkdrop.app/Contents/MacOS/Inkdrop ) to get console outputs from the main process.
I havenāt been running into this issue lately, and was never able to reproduce it reliably. I assume the issue was with my local machine and not with Inkdrop; I just wanted to see the logs so I could debug. If it comes up again I will run Inkdrop from the Terminal and see if there is anything interesting.
