Inkdrop Desktop v6.1.4
I’ve been working on making the editor stable and performant.
Editor performance improvements
I revisited the editor decoration features and found some bottlenecks.
  • Scan only the visible lines instead of the whole document on every scroll:
    • Codeblock, blockquote, and alert decorations
    • <mark> tags
    • Completed-task strikethrough
Also, inline image widgets now avoid recalculating their positions.
Bugfixes
  • Editor: RangeError: Invalid position N in document of length N — a bare URL at the very end of a note broke table, alert, blockquote and code block highlighting
  • Editor: RangeError: Mark decorations may not be empty — an empty <mark></mark> broke inline mark highlighting
  • Editor & Preview: Scroll sync randomly stops working
  • Editor: Table highlighting was missing when the table begins above the visible area, e.g. when scrolling up from the bottom of a long table
  • Editor: Highlighting was missing or flickered in a long note until you typed or scrolled — decorations were built against a syntax tree that had not yet been parsed down to the visible text
  • Editor: Multi-line quote command doesn’t properly deal with list indents
  • Editor: Line insert popup out of view when not wrapping lines (Thanks @Magnus)
Tool updates
Live Export v0.2.2
This is a NodeJS library to help programmatically export notes for building blogs, allowing you to use Inkdrop as a CMS.
This release revives the project on a modern toolchain and fixes several bugs that had left the library broken at runtime.
Blog template update: Astro 7 support
A template for creating a simple blog using live-export now uses AstroJS v7.
This is an example project of using Inkdrop as a CMS for building static websites.
Here is a repository:
Check out the tutorial docs:
MCP Server v1.5.0
To update:
npm i -g @inkdropapp/mcp-server@latest
Docs: Integrate AI agents with the MCP Server - Inkdrop User Manual
New tools
  • Add create-book and update-book tools for managing notebooks
  • Add create-file and read-file tools for working with attachments
Fixes
  • update-tag now updates via the per-document endpoint, so partial updates no longer need to resend unchanged fields and no longer reset the tag’s color to default
Thanks @Blake_Miller for the feedback.
New doer joined!
Thanks @Khouw_Devin :laughing:
Help spread the word​:folded_hands:
I’d really appreciate it if Inkdrop has been useful in your workflow and you could leave a review on AlternativeTo!
https://alternativeto.net/software/inkdrop/about/
