Inkdrop Desktop v5.6.0 beta.3
Hey Inkdroppers,
Thank you for testing the beta version and reporting issues!
Bug fixes
  • fix(server): Local HTTP server not working (Thanks Raivis)
  • fix(editor): floating action buttons not appearing right after the launch (Thanks Lukas)
  • fix(ipm): The CLI command ipm install not working (Thanks Raivis)
@Lukas I’ve changed the way to bundle the app in this release, where I enabled Asar again. As far as I can see, plugins work fine but can you please check in your environment as well?
