Download here!
Improvements
- Dev: Add a link to dev-tools plugin in Preferences
- Editor: Remove the file extension from the alt attribute when inserting an image from a file
- Before:
[filename.jpg](inkdrop://file:****) - After:
[filename](inkdrop://file:****)
- Before:
- Theme: Switch the default light/dark themes automatically based on the system preferences (Thanks Mac and Ben)
- You can disable this behavior by setting
core.toggleDarkThemeAutomaticallytofalseinconfig.cson
- Internal: Bump up SQLite version
Bugfixes
- Export: Inline styles not working in exported notes as pdf or html
- Export: Canceled dialogs not being handled properly
- Exprot: Do not exclude notes with empty body (Thanks Magnus)
- UI: The note list not updating if a conflict happens
- Editor: The editor should refresh after changing custom stylesheets
- Editor: The app crashes when inputting a title longer than 128 characters (Thanks Danielsec)
- Markdown Preview: Task checkboxes get wrong position when the item is empty
- Local server: The numeric parameters for
_changeswork incorrectly - Local server:
GET /tag:<id>not working - App: Notes not being saved when immediately quitting after editing (Thanks Ryuki)
