Since the day before yesterday, when I opened the latest version of Inkdrop on the macOS platform, it always displayed blank after login (as shown in the picture). I have uninstalled it and installed it twice. It still cannot be solved. At present, most of the plugins and themes are also invalid. , But iOS and iPadOS are normal.
There are important data in Inkdrop that need to be updated using macOS, please help to solve it as soon as possible, thank you!
Interesting.
Seems like the local database is not loaded properly for some reason.
I guess the problem resides in the main process.
Could you please run the app from terminal by the following command?
I’m sorry to reply to you so late!
I have followed your instructions. It is indeed a problem that the local data is successfully loaded, but “Reload” did not solve this problem. The screenshot of the error prompt after running the command in the terminal is as follows, thank you for your reply to this problem!
The app says that your config has a duplicate key “body”.
I suspect that you have a wrong configuration in your keymap.cson or config.cson something like:
