Hi, I’m trying to migrate from Bear notes to Inkdrop but can’t figure out how to get Inkdrop to include local image files. Bear exports images linked from its Markdown notes as assets in a subdirectry. When importing the MD files into Inkdrop, is there any way to have it copy the linked local images into its database as well?
If that’s not possible, any workaround? I have almost 2,000 notes, many of which have locally stored images linked in them. Thanks!
Thank you for the report.
Looks like there is a bug where it doesn’t work when you import notes with images from Bear because it encodes the image paths as URL. For example, it replaces whitespace with “%20”, which causes the issue.
I’ll fix it in the next release.
That’s weird. The app should only check the file size and type.
Are they image files? It doesn’t support other file types.
If so, I need to reproduce it.
Would you mind providing me the note with the files to debug?
This appears to still be occurring, but with different symptoms.
I am trying to convert from Bear so that I can use the same editing platform on my Windows PC issued by my new company, and in my import of a .md file exported from Bear, the issue took this form in Inkdrop 5.5.1:
