I appreciate the new features added on ver.5, but I donāt get the āRemember navigation stateā one.
I mean, I donāt get when and how I can use the function.
I tried swiping on the note, since I use mac, after browsing around a few notes, but nothing happened.
Thanks for the reply.
It helped a lot !
Actually, I looked for the manual, only to find that Iām pretty bad at finding what I look for
By the way, this feature helps me so much, since I refer other notes frequently.
